Date/Time: Fri, 31 Jan 2025 09:13:43 +0000
SCSting::Left does not work
View Count: 663
[2019-04-20 03:54:25]
User189399 - Posts: 43
I have tried with the sample code from SC.
SCString TestStr1="It is a test";
TestStr1.Left(-5);
sc.AddMessageToLog(TestStr1,0); //Output "It is a test" not the expected "It is a"
[2019-04-20 04:21:57]
You cannot use a negative number with Left. It needs to be a positive number.
[2019-04-24 08:37:24]
I captured the description of SCString::Left from the SC web site
ACSIL Programming Concepts
It said the count support -ve number. Pls note I have also tested with +ve count number. It return the same result without removal the chars from the left.
SCString::Left()
Type: Function
SCString Left(int Count) const;
The Left() function returns the substring from the SCString object that is the number of characters defined by Count starting from the left side (beginning) of the SCString object when Count is positive. If Count is negative, then the substring starts at the left side (beginning) of the SCString ojbect, but has Count number of characters removed from the right side (end) of the SCString object. If Count is negative and would result in the return of no data, then a NULL string is returned.
[2019-04-24 09:11:12]
We do not know where you are making a mistake. There are definitely no problems. This has been verified with this test code:
  SCString Test("Test");
  SCString LeftString = Test.Left(2);
Date Time Of Last Edit: 2019-04-24 09:11:33
