Date/Time: Fri, 31 Jan 2025 05:58:17 +0000
Scaling TPO chart
View Count: 1569
[2019-04-18 19:07:30] |
User798235 - Posts: 10 |
Hi iam struggling with overlapping tpo letters, i cant seem to find a setting that the numbersbar study have to scale letters between X and Y. Is it possible to do that, if not is it something you could add to the tpo study, as the numbers bar already have that function? Best regards magnum Date Time Of Last Edit: 2019-04-18 19:08:41
[2019-04-18 21:54:40] |
John - SC Support - Posts: 37621 |
Refer to the following for solutions to this: Time Price Opportunity (TPO) Profile Charts: Solving Overlapping TPO Letters For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-19 10:43:33] |
Hi! Yes i have played around with these settings, im looking for a solution like in this thread Chart Scaling issues To have theme automaticly change size, is this implemented? Date Time Of Last Edit: 2019-04-20 00:50:25
[2019-04-19 14:50:43] |
Found the solution by setting fontsize to 0 and X&Y to constant relasionship. solved it and should probably be documented under the section you sent me about overlapping TPO letters! Best regards, magnum |
[2019-04-20 00:51:32] |
Yes if the Letter Font Size Input setting is zero, it will be automatic.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-20 00:56:59
