Date/Time: Fri, 31 Jan 2025 09:08:49 +0000
KEYBOARD SHORTCUTS Wrong function
View Count: 668
[2019-04-18 18:33:48] |
User264055 - Posts: 8 |
Hi, when l try to create command key which a sell trial stop, but it works as a market sell order Date Time Of Last Edit: 2019-04-22 12:51:52
2019-04-18_21-27-16.jpg / V - Attached On 2019-04-18 18:33:18 UTC - Size: 73.29 KB - 287 views |
[2019-04-28 14:35:24] |
dear, I cant create shortcuts key for sell trial stop, it works as a market sell order |
[2019-04-29 21:35:17] |
Since this is a Stop type order it has to be below the Last price or it will automatically fill. Thereore, you need to enter the Offset from Reference Price as a negative value. If you make it -5 it will work as you want.
