Date/Time: Mon, 24 Feb 2025 17:50:05 +0000
Updated File
View Count: 707
[2019-04-18 17:54:23] |
User38606 - Posts: 108 |
Ok. Some functions are not indeed supported in the newer spreadsheets. For instance, COUNTIF worked in old version of the spreadsheets, yet it returns "NAME". That is why my study is down. So how do i go around this? Thank you
[2019-04-18 18:00:15] |
Refer to: Spreadsheet Functions: Using the Equivalent of COUNTIF, AVERAGEIF, MAXIF, MINIF, SUMIF Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
