Date/Time: Fri, 31 Jan 2025 06:07:17 +0000
Sierra Chart - Ongoing Screen Refreshes
View Count: 606
[2019-04-18 17:43:18] |
TapeReader - Posts: 89 |
Sierra Chart [1902] has begun refreshing my charts on a continual basis. I have removed all studies from a test chart, yet the issue remains (Short video attached showing behavior). There have been no recent changes to the hardware. I see nothing in the log files that hint at the root cause. Any insights here? Thanks, C |
Sierra Chart - Refresh Issue.mp4 - Attached On 2019-04-18 17:41:39 UTC - Size: 139.3 KB - 373 views |
[2019-04-18 17:47:49] |
This has been resolved. Update to version 1904.
[2019-04-18 17:59:35] |
Thanks..1904 fixed it. This issue is closed. |
