Date/Time: Fri, 31 Jan 2025 05:54:42 +0000
Activity Log dollar values
View Count: 621
[2019-04-18 17:32:54] |
User698315 - Posts: 4 |
I'm in sim mode and trading NAS100. That should be $5 a point, right? However I am trading 5 contracts and it's only showing something like $1 a point...for all 5 contracts. I That should be $25 a point. Do I need to set a value for the instrument or something?
[2019-04-18 18:01:11] |
We are not sure of what the currency value per tick for this actually should be. You can adjust it: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
