Date/Time: Fri, 31 Jan 2025 06:09:57 +0000
Accumulate Time and Sales
View Count: 1683
[2019-04-18 16:00:14] |
baystreetbull - Posts: 4 |
Is there a study that will allow me to accumulate the time and sales BID and ASK Trades with a line on close chart? Difference study only allows you to add one source of data instead of 2. Thanks in advance. Cheers |
[2019-04-18 18:02:08] |
You can use this study: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-19 12:34:56] |
So I would apply the Cumulative Sum Study on a Time and Sales Volume Study? When I do that I can only select either the Bid or the Ask but not a combination of them both, my goal is to have the total amount of Ask trades Minus the total amount of Bid trades then accumulated on a line on close chart. Is this possible with Cumulative Sum or any other study? Happy holidays Thanks in advance. |
[2019-04-19 22:48:22] |
You can do these calculations. Refer to this page: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
