Date/Time: Fri, 31 Jan 2025 06:16:42 +0000
Chart --> Start Scan - ASCIL Command
View Count: 761
[2019-04-18 15:21:09]
CarlRostron - Posts: 80
Hi, I have two watchlists I want to scan through. Both watchlists underlying data form together a Ratio Chart and so I want to scan through both sets of watchlists not just one of them.
I'm assuming this functionality isn't possible and so I was going to do it in ASCIL. But I couldn't find a command to Start the Scanning Process through Chart --> Start Scan. Is this Command available at all in ASCIL so I can call it in ASCIL code?
[2019-04-20 01:00:41]
This is not supported through ACSIL.
[2019-04-20 06:24:53]
Can you point me to the ASCIL function call that allows me to change the chart Symbol for different charts please and I can code this myself?
[2019-04-22 21:48:11]
There is not a way to change the symbol of another chart. Only the symbol of the chart the custom study is applied to can be changed.
Date Time Of Last Edit: 2019-04-22 21:49:14
[2019-04-23 11:14:57]
Please can this function be considered for future development as I believe it would be helpful.
Thanks for great software and support.
Regards
