Date/Time: Fri, 31 Jan 2025 08:46:33 +0000
[Programming Help] - Array Bounds violation in dynamic arrays
View Count: 697
[2019-04-18 05:05:33]
User255315 - Posts: 133
Hi SC,
I have a question regarding dynamic arrays. It might be too vague but this is how i can explain the problem:
I use dynamic arrays to constantly store values pertaining to every price as the session progresses but when there is a new low or high i.e extension in the array size, i get thrown an exception. Would this be related to an array bounds violation? If so, how do i handle it. Even guidelines relating to this are welcome. To clarify further, i am running a loop over hi to lo to calculate said values for every price, and am getting an exception when those lo to hi indexes change.
Thanks in advance.
[2019-04-18 17:58:15]
There is no way we can know where you are going wrong unless we were to examine the code and that is not within the scope of our support.
[2019-04-27 06:14:42]
Hi SC!
If its possible for you to have just a quick look at the following loop in which i populate a dynamic array with VaP for the range of the day through sc.VolumeAtPriceForBars. I am fairly certain that this loop is throwing the exception. Any suggestions or guidelines regarding this are welcome.
s_VolumeAtPriceV2* p_fill= NULL;
  int ProfileIndex = 0;
  int PriceIndex = 0;
  int ht = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(Index)-1;
  range[Index] = ht;
  for (int KeyIndex = 0;KeyIndex < ht+1; KeyIndex ++)
      sc.VolumeAtPriceForBars->GetVAPElementAtIndex(Index, KeyIndex, &p_fill);
      //verify the pointer is not a null, otherwise an exception will occur
      if (p_fill)
        float value= p_fill->Volume;
        p_VAP[KeyIndex]= value;
        //youre storing VAP in dyn mem
This is the corresponding error message:
Warning: The Custom DLL study "daily-mod.scsf_SelfContainedVB" has just caused a CPU exception. | 2019-04-26 17:11:59 *
Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2019-04-26 17:11:59 *
Thanks in advance!
