Date/Time: Fri, 31 Jan 2025 10:42:02 +0000
convert the spreadsheet
View Count: 1032
[2019-04-15 20:19:44] |
User14686603 - Posts: 14 |
how to convert the spreadsheet to the new version from scwbf file to scss file
[2019-04-15 21:25:57] |
Sawtooth - Posts: 4164 |
Old Spreadsheets (scwbf) are only supported in versions 1310 and earlier. Only New Spreadsheets (scss) are supported in versions later than 1310. You might want to install another instance of Sierra Chart for New Spreadsheets, so that you also have a version that will open Old Spreadsheets. You can copy/paste the scwbf (or both the chartbook that uses the scwbf and the scwbf file) from the Old Spreadsheet version's \Data folder to the New Spreadsheet version's \Data folder before conversion. Open the scwbf (or chartbook that uses the scwbf) in a newer version of SierraChart, and it will attempt to automatically convert it to scss. The scwbf will be retained. However, if the scwbf is complex, or has functionality that is no longer supported, you might need to tweak a few things, or in some cases, a lot of things. Working with Spreadsheets: Difference Between New and Old Spreadsheets |
[2019-04-15 22:03:30] |
Privately attach the file you want to convert here and we will do this for you.
[2019-04-19 11:37:08] |
please convert these files
Date Time Of Last Edit: 2019-04-19 11:38:55
Private File Private File Attachment Deleted. |
Date Time Of Last Edit: 2019-04-19 11:38:28
Rectangle-.StdyCollct - Attached On 2019-04-19 11:38:12 UTC - Size: 7.67 KB - 374 views Private File |
[2019-04-24 08:11:27] |
These are still pending conversion. We will have them to you as soon as possible.
[2019-05-02 21:27:15] |
The converted spreadsheets are attached to this ticket: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets&Ticket=1556832408918 We notice some of the formulas are referencing another spreadsheet file and this is not supported in new Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
