Date/Time: Mon, 10 Mar 2025 11:16:58 +0000
Auto trading new TT connection
View Count: 1238
[2019-04-15 20:00:31] |
ertrader - Posts: 682 |
Hi Support, When I auto trade with the new TT connection, I get the following error: SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: Unsupported order type.. Text: Parent order. Tag: ES1.twconfig. Internal Order ID: 14977. Service Order ID: 1956. Symbol: ESM19_FUT_CME | 2019-04-15 15:53:18 I have order type set to SCT_ORDERTYPE_MARKET_IF_TOUCHED in my ACSIL. Can you please let me know what order types I can use? Or, should I use the configuration file order type and remove the below from my ACSIL? The configuration file is set to Market. NewOrder.OrderType = SCT_ORDERTYPE_MARKET_IF_TOUCHED; I did look through the documentation but did not see recommendations as it relates to the new TT connection. regards Date Time Of Last Edit: 2019-04-15 20:39:18
[2019-04-15 21:14:51] |
TT is just passing the orders directly over to the exchange. So the CME is not supporting market if touched orders. In this case use a client-side market if touched order: Order Types: Market if Touched - Client Or if you just want to use a market order you can use that but we are not really sure of the context of what you are doing so we are not sure what to recommend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 21:15:11
[2019-04-16 15:00:40] |
Thanks, that was it and it's working now.
