Date/Time: Fri, 31 Jan 2025 06:10:11 +0000
(NOT USER DISCUSSION) Trading Chart DOM Volume bar relative sizes
View Count: 943
[2019-04-15 16:48:24] |
samual sprat - Posts: 343 |
Hi, When I use the Chart Trading DOM and set 'Show Volume Bars' to true in 'Customise Chart DOM Columns' for 'Ask Size/Sell Column' or Bid they don't display relative size between them. So the Ask Size bar of value 10 can be the same as a Bid Size value of 100 and this is very confusing. Same for 'Combined Bid/Ask Market Depth Pulling/Stacking' and 'Combined Bid/Ask Size' . Is it possible to make the volume bars on these types of columns relative otherwise the using them instinctively is impossible without paying attention to the number values too? Not sure why but the original post was set to user discussion, so can be deleted https://www.sierrachart.com/SupportBoard.php?ThreadID=41860 Thanks S |
[2019-04-16 09:59:14] |
Why is this a user discussion again? It's a feature that isn't present and no user can fix? Sierra Support please fix this. Date Time Of Last Edit: 2019-04-16 10:00:08
[2019-04-16 15:14:23] |
John - SC Support - Posts: 37621 |
It is a User Discussion because it is a feature that isn't present . Refer to our policy here on this:Meaning of User Discussion or Programming Help We understand your request, and we want to change everything we can to make it as perfect as we can, but there is a lot to do and we cannot give any information on when we will get to something, as we simply do not know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-16 16:17:09] |
Ok thanks for explaining, John
[2019-04-17 18:17:14] |
User915027 - Posts: 17 |
it seems to be the same request already done here Trading DOM improvement | Post: 170341 |
[2019-04-20 02:40:33] |
This will be supported in the next release.
