Date/Time: Sat, 01 Feb 2025 19:04:46 +0000
Change Input Value in Market Depth Historical Graph over multiple charts, at once
View Count: 752
[2019-04-15 15:09:16]
osaga - Posts: 53
Hello SC
I am using the Market Depth Historical Graph on five charts. They all use the same symbol. I want to change the input value "Graph Only Quantities Greater or Equal To" on all charts at once. Right now I have to go into each chart to makes these changes and it takes time, especially since I change this value often. Unfortunately, the Study Overlay does not work with this study. The charts use variously different studies so I can't use chart linking.
Is there a way I can make the change once and it will make the change on all the studies? Or is there another way to accomplish this?
Thank You
[2019-04-15 18:11:25]
Normally, we would say use the Chart Linking feature and link the Chart Studies:
Working With Charts: Chart Linking
Otherwise, there is not another solution.
[2019-08-01 14:59:07]
osaga - Posts: 53
Is using the spreadsheet a potential solution to quickly change this Input Value?
[2019-08-02 05:31:27]
No. You really just have to use the Chart Linking feature and link Chart Studies. Or use the Advanced Custom Study Interface and Language to programmatically change study Inputs.
