Date/Time: Sun, 24 Nov 2024 16:49:22 +0000
SC submit order to TT FIX
View Count: 1324
[2013-11-21 12:07:15] |
batman_ - Posts: 190 |
Can i use SC's cme data feed and submit order to TT FIX adapter? because i am not comfortable with their bid and ask feed.
[2013-11-21 14:18:59] |
Yes. This will work well. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
