Date/Time: Thu, 18 Apr 2024 01:02:27 +0000
Horizontal Lines Study
View Count: 990
[2019-04-14 17:20:20] |
Gustavo - Posts: 72 |
The "Set All Subgraph Display Settings to Be Same as First" is not working for me when set to YES. Could you confirm the feature is working correctly on your side? I'm on SC version 1894 64-bit. Thanks, |
[2019-04-15 10:31:56] |
The functionality for this was disabled. It will be enabled in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 10:32:02
[2019-05-18 23:01:16] |
I have downloaded the latest release, 1919 64-bit, and the "Set All Subgraph Display Settings to Be Same as First" is still not working. Any updates on when that feature will be corrected? Thanks, |
[2019-05-20 16:47:14] |
This has been tested and definitively works. No problem at all. This is very straightforward and simple.
[2019-05-20 17:40:31] |
Thanks, I figured what I was doing wrong.
