Date/Time: Sun, 23 Feb 2025 18:34:02 +0000
Detach chart book
View Count: 2458
[2019-04-14 10:12:30]
User343901 - Posts: 66
Hi support
Is it possible or would it be possible to allow the detaching of an entire chartbook in the same way a chart window can be detached? I use a chartbook for each instrument and it would be very convenient to pull the entire chartbook to a second screen and let sierra manage the chart window layout rather than having to do it manually.
[2019-04-14 10:50:35]
The method is by using separate instances:
Detaching and Attaching Chart Windows: Detaching Chartbooks
[2019-04-14 11:51:20]
Thanks for your reply. I have tried that method before but have been cautious of it because 1) it's a separate connection to the same feed and 2) the setup is quite inconvenient as it duplicates all data to a new Data folder.
Are there any potential issues with trading on 2 instances on the same feed at the same time?
I have tried setting the second instance to use C:\SierraChart\Data\ but on restarting the program this setting doesn't stick and reverts to the default second instance Data folder.
Are there any issues/conflicts with pointing the second instance to the primary Data folder?
Many thanks
[2019-04-14 20:04:16]
It is a very fast internal connection. This should not be a concern at all.
No definitely not.
Yes this will cause problems.
Date Time Of Last Edit: 2019-04-14 20:04:29
