Date/Time: Fri, 31 Jan 2025 03:13:25 +0000
Intraday data for S&P 500
View Count: 1358
[2019-04-13 13:19:27] |
User683770 - Posts: 2 |
Dear all, I would like to ask you about the retrieving intraday data (timeframe of 30sec) for all stocks in S&P 500 for the whole year 2018. Is there a simple way how to do so or do I need to do it seperately for every single stock? Thank you very much for your help! Michaela |
[2019-04-14 21:29:04] |
Yes this is supported. Here is the relevant documentation for this: Changing the Symbol of a Chart: Automatically Inserting Symbols for Exchange or Index Changing the Symbol of a Chart: Downloading Historical Intraday Data for Symbols List You will also want to set the Intraday Data Storage Time Unit to 30 seconds: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-14 21:29:44
