Date/Time: Fri, 31 Jan 2025 03:13:36 +0000
[User Discussion] - programming request for Target and stop indicator
View Count: 840
[2019-04-13 12:23:37] |
grantx - Posts: 244 |
This is what I have achieved so far using a custom study: I want to see my trade parameters on the chart in real time so I created a custom study which works off the current Priceline. For instance, if I set my stop to 80 ticks and a target to 100 ticks, then I as price moves, the stop and target move on the chart (see screenshot). The problem: Its a hassle to go in and change the parameters of the study every time I want to adjust the stop or target. So, the main question is: Is this a programmable feature? See my 2nd screenshot. I want to be able to simply enter the trade parameters into boxes on the toolbar (or the trade window) and the lines will reflect on the chart. Thank you. |
2019-04-13_09-29-00.png / V - Attached On 2019-04-13 12:13:05 UTC - Size: 19.77 KB - 327 views Sierra Programming.png / V - Attached On 2019-04-13 12:13:14 UTC - Size: 9.44 KB - 323 views |
[2019-04-13 21:49:53] |
ForgivingComputers.com - Posts: 992 |
I can create one for you. You would not be able to use the Control Bar, but you could use the Trade Window. I sent you a direct message request. BradH |
