Date/Time: Fri, 31 Jan 2025 03:05:29 +0000
Chartbook display
View Count: 723
[2019-04-13 09:48:43] |
User27542 - Posts: 20 |
Hello, I have many different chartbooks which I currently have to scroll through (the scrollbar just under the toolbar at the top)but instead would like to have the names of all of them displayed, so I can see them all at the same time, without having to scroll. This means having the names of all my chartbooks displayed in more than the one row that is currently allowed. Is there any way I can do that? With thanks for any help you can give. Regards, tme246 |
[2019-04-13 20:41:50] |
This capability is coming with the new tab controls we have developed in Sierra Chart.
