Date/Time: Fri, 31 Jan 2025 03:09:27 +0000
[User Discussion] - do not save Market Depth files in sub instance?
View Count: 748
[2019-04-13 05:02:41] |
whats1thingnow - Posts: 407 |
sorry, i cannot locate from search the support board nor from the docs if this is possible? i don't want to save Market Depth files in the sub instance folders... to save disk space and i read it's faster to not save the market depth files? thanks for the help! |
[2019-04-13 20:40:55] |
Each sub instance maintains its own files. Unless you do not want to use the Market Depth Historical Graph study in the sub instance, those depth files need to be there.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-13 20:41:12
