Date/Time: Fri, 31 Jan 2025 03:15:36 +0000
Windows 10 & Multiple Chart Books
View Count: 1043
[2019-04-12 20:57:59] |
User240019 - Posts: 112 |
Windows has a snap feature where you can easily separate the windows and they stick to their location on the screen, whether tiled, or divided horizontally, etc. This is great for multiple chart books because I can easily make use of my space economically. The problem I'm having is that every time I switch chartbooks they unsnap and move and auto-resize to something I didn't set them to. Is there any way to get this feature to work with Sierra Chart? The only work around I've been able to get is either doing two instances of sierra (not great if you trade more than 2 securities) and using virtual desktops or trying to size them close enough to the edges without engaging the snap feature. Please let me know if there's anything that can be done. |
[2019-04-13 07:34:48] |
User993113 - Posts: 74 |
I'm using display fusion with windows 10, this never happened to me It could be an operating system issue |
[2019-04-13 20:04:47] |
THAT DID IT!!! I hated sierra for this reason! Man I'm so glad that's fixed!! Thank you! |
