Date/Time: Fri, 31 Jan 2025 02:58:45 +0000
options trading
View Count: 885
[2019-04-12 13:19:14]
User809923 - Posts: 1
Would it be possible to get more info/tuto regarding the use of the trading DOM for options trading? I use the CQG data and the SC DOM seems to be fitted for futures only.
Thanks for your help!
[2019-04-12 17:27:12]
Not really. It can be used with any type of symbol. Refer to the documentation here:
Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder
One thing you may want to check is that the tick size is set correctly:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Date Time Of Last Edit: 2019-04-12 17:27:58
