Date/Time: Fri, 31 Jan 2025 03:31:10 +0000
LINK Number color for tab
View Count: 631
[2019-04-12 07:33:13] |
nicktrader - Posts: 733 |
With the new rel. 1899 I have to set the color for the tab but I can't find it. I am using LINK #20. I had the problem with the fonts and it seems to be solved. Txs |
[2019-04-12 17:35:12] |
Support for this will come next week.
