Date/Time: Fri, 31 Jan 2025 03:05:29 +0000
i CAN NOT LOG IN
View Count: 746
[2019-04-12 06:54:50] |
CLAUDINE PETIT-ROUX - Posts: 3 |
Hello, I can not connect my account. I asked Stage Five the Rithmic stream. I use these identifiers to connect to dormanaccount. I connected to SierraChart with username : but since I have Stage Five and Rithmic it is not possible. I contacted Stage Five about it and they advised me to ask you to change the userneme and password for me. Thank you to help me. Claudine Date Time Of Last Edit: 2019-04-12 08:50:35
Message erreur.PNG / V - Attached On 2019-04-12 06:53:54 UTC - Size: 10.8 KB - 255 views SIERRA CHART CONNEXION.PNG / V - Attached On 2019-04-12 06:54:18 UTC - Size: 200.33 KB - 285 views |
[2019-04-12 17:55:10] |
Do not post any usernames or passwords here. We have removed those. Did Stage 5 provide you a Username and Password for Rithmic? Follow the instructions here and enter those as specified: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-12 17:55:22
