Date/Time: Thu, 06 Mar 2025 13:08:40 +0000
supply demand zones on SC
View Count: 4029
[2019-04-11 22:29:06]
User758506 - Posts: 9
hello,
I didnt find any ticket about possibilities to draw on SC supply demand zones. could you help me pleasev? thank you very much
[2019-04-12 05:26:49]
It depends on how you need those calculated. Can you provide a description of this.
[2019-04-16 10:59:20]
I would like to spot levels where there have been several stacked and massive imbalances. thanks for your support
[2019-04-16 17:30:10]
You will probably want to use this study:
Volume at Price Threshold Alert V2
It is also able to draw horizontal lines forward where certain volume conditions have been met at a price level within a chart bar.
Date Time Of Last Edit: 2019-04-16 17:30:41
[2021-06-15 21:49:01]
Chadly - Posts: 65
This is a great idea. Supply and Demand zones are becoming very important and popular. It would be very awesome to have a supply and demand zone type indicator. I'm not sure how others are doing it, but they're out there. Attached are some examples.
SC is incredible and rolling out indicators so I'm sure you all would be interested.
I think these would be very awesome in the future:
Chandelier Stop (tied to ATR input values)
Supply and Demand zone (able to write in a simple alert to say "if in supply zone then true" so you can tie it into alerts)
Elliot Wave Indicator
Candle Pattern (not just candles but multiple candles forming a pattern) finder such as Head and Shoulders indicator etc.
Anyway....thanks guys
Chadly
imageSDZone.jpg / V - Attached On 2021-06-15 21:47:28 UTC - Size: 87.69 KB - 1037 views
[2022-02-04 13:12:50]
madness99 - Posts: 35
Hi Chadly,
How did you create that supply and demand zone?
J
[2022-02-05 16:50:34]
ForgivingComputers.com - Posts: 1021
Supply and Demand Zones are somewhat subjective. As Sam Seiden Sez, you have to "train your eyes" to recognize them.
If you have a set of rules for what defines the zones, then it could be programmed.
