Date/Time: Fri, 31 Jan 2025 03:03:30 +0000
How to get Bitmex data for XBT perpetual swap through CQG FIX Trading data feed
View Count: 746
[2019-04-11 20:49:37] |
User38334 - Posts: 2 |
Cannot chart the symbol when i select it from Chart Settings
[2019-04-12 15:26:30] |
John - SC Support - Posts: 37621 |
You will need a direct account to access those symbols: Direct Sierra Chart Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
