Date/Time: Fri, 31 Jan 2025 03:08:34 +0000
options trading via dom
View Count: 715
[2019-04-11 20:11:44] |
Pawel Wozniak - Posts: 1 |
Hi, I want to trade options via prica ladder (DOM). Is there any options chain board to see in Sierra? Best, Paul |
[2019-04-12 05:21:55] |
In the case of CQG which you are using, refer to: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
