Date/Time: Mon, 03 Feb 2025 07:01:32 +0000
Copy trades into another instance of SC ?
View Count: 2342
[2019-04-11 15:45:48]
stever62 - Posts: 12
Is it possible to take trades generated in 1 instance of SC and send them to another instance of SC ?
[2019-04-11 17:48:36]
The only way is by exporting the order fills from one instance and importing them into another:
Trade Activity Log: Importing and Exporting Data
Although you do not have to do that procedure when using this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Date Time Of Last Edit: 2019-04-11 17:49:34
[2019-04-11 19:51:15]
Using option 2 above, can I send the same signal through TTFix to 2 different accounts at the same time?
[2019-04-11 22:48:40]
Yes you can.
That actually is a feature that we have developed but we did not yet release it for live trading but we are able to do that now. It will be active in the next release.
[2019-04-12 01:11:16]
Thanks. Being able to send my trades to more than 1 account is huge.
I assume the documentation will be here...
Order Allocation to Trade Accounts
[2019-04-12 17:56:47]
Yes we will have this documented in the next couple of days.
[2019-04-13 19:54:21]
John - SC Support - Posts: 37656
The documentation for this is now available at the URL you listed above.
[2019-05-18 16:27:50]
I have gone through all of the links above and still don't understand if the solution will do what I was asking.
Let me give an example - I want to place a trade on my Sierra chart and have that trade routed to 2 different broker accounts - 1 in my name and a second in my daughter's name. I will have the power of attorney in place with the broker for my daughter's account. Using FIX and TT, is there any way I can do that.
When I went through the allocation feature that you added, it looks like it can place the trade in 2 different sub accounts to a main account, but not 2 different accounts owned by different people.
If it makes it easier, both accounts can be at the same brokerage.
[2019-05-18 17:40:38]
Yes this is fully supported. You would submit the order on one account and can automatically have it copied 100% to the other specified account.
This is the preferred service to use:
Date Time Of Last Edit: 2019-05-18 17:41:36
[2019-10-28 17:18:48]
samual sprat - Posts: 343
Hi. Is this copy trade functionality still working? so copy trades taken on a rithmic account to denali/cqg/tt etc?
[2019-10-28 22:45:00]
User460398 - Posts: 11
Does this also work if you have 2 login credentials at rithmic.. No way I can swap the 2 user accounts to 1
[2019-10-29 05:43:48]
In regards to post #10 and #11 that is not supported.
If you have trading accounts on the TT system at different clearing firms, or the same clearing firm, you can do the trade copying with this service:
[2019-11-03 20:41:48]
T44 - Posts: 363
Questions on this feature. I place a limit order to buy 5 lots and the allocation is set up to "copy" to two accounts, brokerA and brokerB.
0) did I place a total order for 5 lots or a total order for 10 lots - 5 in brokerA and 5 in brokerB?
1) is the displayed working quantity on chart/DOM 5 or 10?
2) 7 lots are filled. Is the displayed quantity working quantity now 3 or 0?
3) the market gets away from the price with 3 unfilled. My position is long 7, split in "some way" between brokerA and brokerB. I place a market order to sell 7 contracts. How is that fill allocated? (and how does it work if those 7 contracts fill at two price levels?)
I do have a use for this but it would need more documentation to be comfortable that I knew how it would work. Thanks.
