Date/Time: Fri, 31 Jan 2025 03:21:58 +0000
Windows Error Code 1392
View Count: 938
[2019-04-11 14:24:37] |
Joshua Dawson - Posts: 5 |
Hello, The system keeps printing multiple file logs on an error code 1392. The file or directory is corrupted and unreadable. How can I fix this? Also, I seem to lose connection with Sierra a lot during the day. Is there a way to fix that? |
[2019-04-11 17:42:38] |
Log into the Support Board with your current account through Help >> Support Board. After that provide a copy of the Message Log following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
