Date/Time: Fri, 31 Jan 2025 03:18:55 +0000
version 1899 tab control: changing tabs by keyboard shortcuts doesn't select the active on
View Count: 767
[2019-04-11 08:57:08] |
AlexPereira - Posts: 197 |
Hi, So testing version 1899 with new tab control: when I change tabs with the keyboard shortcuts ( next and previous ), the chartbook changes, but the tab control still displays previous chartbook as active, and not current one. EDIT: also closing the chartbook seems to leave the closed tab on the tab control bar Thanks ! Date Time Of Last Edit: 2019-04-11 09:06:28
[2019-04-11 09:12:04] |
We will resolve this.
