Date/Time: Fri, 31 Jan 2025 03:07:18 +0000
replay function
View Count: 676
[2019-04-09 17:13:03] |
User531621 - Posts: 103 |
i am not set up for replay ... what do you need from me to be able to access this function. thank you
[2019-04-09 18:19:11] |
Just follow the instructions here: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-09 20:46:29] |
still doesnt work. i went to windows to reset, and it doesnt do anything. need further help on this. thanks
[2019-04-10 18:44:52] |
Do you see the replay control panel? If so, did you scroll the chart back before starting the replay? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-10 19:11:43] |
seems to work now.. thank you so much
