Date/Time: Fri, 31 Jan 2025 03:15:53 +0000
quote spreadsheet
View Count: 1151
[2019-04-09 13:24:22]
User28682 - Posts: 233
How do you delete columns? There is a "delete row" option, not a "delete column" option that I can see.
Actually I just want to get rid of some the columns in the Quote sheet.
Date Time Of Last Edit: 2019-04-10 03:34:26
imagequotes.png / V - Attached On 2019-04-09 13:24:03 UTC - Size: 31.88 KB - 294 views
[2019-04-11 05:04:43]
The columns are controlled through the Field settings. Refer to:
Getting Quotes: Setting Fields to Display
