Date/Time: Fri, 31 Jan 2025 03:08:33 +0000
attached orders
View Count: 807
[2019-04-09 10:46:30] |
nus1 - Posts: 39 |
Hello Sierra, Deselecting "Adjust attached Orders to Maintain Same Offset on Parent Fill" doesn't work, attach orders still maintain same offset on parent adjustment. Date Time Of Last Edit: 2019-04-09 10:48:53
[2019-04-11 16:40:46] |
We definitely do not observe the attached orders being modified to the original offsets on a parent fill and do not know how you are coming to this conclusion. Unless you are referring to modification of the parent order. That option only affects order fills. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-11 16:41:18
[2019-04-12 12:56:43] |
nus1 - Posts: 39 |
I see, is there a way to make attached orders independent after initial placement on the graph?(I am talking about unfilled order on the graph) Purpose for that is being able to adjust, say limit order w/o effecting stop loss position in fast price moving moments. |
[2019-04-12 17:05:58] |
No there is not a way to do this. We do not want to add support for this because it just leads to more support requests when the attached orders do not get modified when someone would expect they would because they do not have the option set right.
