Date/Time: Fri, 27 Sep 2024 03:52:33 +0000
I can't see Chart DOM Settings under Global Settings menu
View Count: 593
[2019-04-09 05:38:37] |
User824913 - Posts: 15 |
Sorry, for probably basic level of my answer: simply I can't see Chart DOM Settings in Global Settings menu. How can enable this menu item? thank a lot |
[2019-04-09 09:25:02] |
Are you using Sierra Chart with Transact? If so, that command is not available with the Sierra Chart made available to them. This is what they have requested. You will need to use Sierra Chart with a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-09 17:51:22
