Date/Time: Sat, 04 Jul 2026 17:59:53 +0000
CQG Sierrachart real time data
View Count: 778
| [2019-04-09 03:28:49] |
| User978290 - Posts: 25 |
Hi, I have connected sierra with cqg Osaka data stream. I'm using 1 min bar on the spreadsheet study. I noticed if there are no trades, there will not be a new entry on the study. eg 4/9/2019 12:09:00 21745 21745 21745 21745 276 92 4/9/2019 12:08:00 21750 21750 21745 21745 253 54 if there are no trades until 12:10:50, it will just be stuck. Wouldn't the entry on 12:10:00 be 21745 21745 21745 21745 0 0 then if on 12:10:50 1 trade on 21750 the output for 12:10:00 will be 21745 21750 21745 21750 1 1 I tried the Include Columns with No data settings on Chart Settings > Advaced Settings, but didn't work. |
| [2019-04-09 09:31:52] |
This is not supported.
