Date/Time: Sun, 24 Nov 2024 16:48:03 +0000
DOM - Last Price at Bid Text and Offer Text
View Count: 1454
[2013-11-20 19:02:19]
User84940 - Posts: 9
I had to downgrade to version 997 because I'm using this through TopStep Trader.
I was using the latest release but got data errors and position errors. They recommended using ver 997 so I have downgraded.
I noticed that I don't have the ability to set the Last Price at Bid Text and Offer Text. (for the DOM) Is there a way to do it in ver 997 ? Or is there a newer version that works ok with TopStepTrader ?
thanks,
Jason
[2013-11-20 21:02:55]
You will need the newest version. This is all we can say. The problem is the newer versions of Sierra Chart uses a FIX connection from CTS, which is still considered a beta according to them.
[2013-11-20 21:44:47]
What is the last Version of Sierra to NOT use FIX ?
[2013-11-20 21:45:58]
997.
[2013-11-21 02:59:29]
ok. I'll follow up with CTS to find out more. thanks.
[2013-11-21 03:18:34]
Please do not ask them about FIX and Sierra Chart versions which use FIX. They have heard enough about it by now.
[2013-11-21 16:18:51]
Haha. ok good. maybe they'll do something about it.
[2013-11-21 19:07:36]
Yes. Clearly a fast and stable FIX implementation was not easy for them.
Date Time Of Last Edit: 2013-11-21 19:07:51
[2013-11-21 22:36:17]
User14266 - Posts: 225
I trade with TopStepTrader. Good luck with CTS as a data feed. I gave up, after so many problems. I use Sierra Chart's new data feed, and finally, I have zero problems. I always run the latest version of SC. Like you, v997 won't work for me because it's missing critical features that I need. If you can afford the $35/month for the feed, I highly suggest you take this route and avoid the many headaches.
