Date/Time: Fri, 27 Sep 2024 03:46:31 +0000
Expired exchange traded spread contracts data
View Count: 936
[2019-04-08 18:12:50] |
User350666 - Posts: 38 |
Dear Support, Can you please let me know if it is possible to open already expired exchange traded spread contracts? I am using the SC Futures datafeed and can open currently traded contracts but not expired ones. I tried to simply replace the expiration month when using the SC spread symbol format, but I'm not sure if thats the correct way: replaced NOB 05-02 M19.FUT_SPREAD.CBOT with NOB 05-02 H19.FUT_SPREAD.CBOT Daily chart loads correctly (a bit slowly), but no intraday data. Can you please advise? Thank you. |
[2019-04-08 20:47:01] |
You can access historical data for expired spreads. Here is the chart: http://www.sierrachart.com/image.php?Image=1554756403735.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
