Date/Time: Sun, 24 Nov 2024 16:29:03 +0000
Keeping price bars on top
View Count: 1669
[2013-11-20 17:32:17]
User70427 - Posts: 5
When I create a chart with both data (price bars) and indicators/studies, I want the price bars to show on top and not be covered up by the indicators/studies. Example: using the Ichimoku Cloud study, the "clouds" cover the data and it can't be seen. There is probably a button or box to check to do this, but I can't find it.
Thanks for any help,
Cliff
[2013-11-20 17:57:43]
Trint - Posts: 115
Have you tried ticking the 'Draw Study Underneath the Main Price Graph' checkbox under Chart Study Settings in the Settings and Inputs tab..?
[2013-11-20 18:23:49]
Thanks Trint...I am just starting to use Sierra Charts and I thought that it possibly meant putting the indicator below the prices. The word behind might have been a better choice on their part.
Thanks for the help,
Cliff
[2013-11-21 06:18:14]
Yes, we can see how Behind would be more clear than Underneath. We may change the wording.
