Date/Time: Fri, 27 Sep 2024 03:49:00 +0000
Order confirmation need disable
View Count: 3817
[2019-04-08 11:00:02] |
User577020 - Posts: 4 |
Hello I start real trading algo, but it always ask me confirm order. All confirmation options is disabled now: Global chart trade settings - Disable order confirmation. How to disable order confirmations ? |
[2019-04-08 12:56:18] |
First for the record, there are no confirmations for automated trading. This is not possible. To disable confirmations on the Trade Window for manually entered orders, refer to: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-08 13:09:03] |
It show me box: CQG WEBApi live order Symbol: Side: Buy Type: market Confirmation can be disabled through menum/M button on the trade window. So how disable this confirmations ? |
[2019-04-08 17:42:30] |
User657944 - Posts: 173 |
Click on th M and open submenu as in the attached photo and you will disable what you want Alberto |
Attachment Deleted. mconfirmation.png / V - Attached On 2019-04-08 17:42:01 UTC - Size: 45.04 KB - 433 views |
[2019-04-08 18:32:57] |
Yes post #4 answers the question. you need to disable the confirmations through the Trade Window for the chart. Refer to this image: https://www.sierrachart.com/images/TradeWindowConfirmationsStep2.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-09 09:07:18] |
All confirmation used in button M is disabled as i written before. Look attached picture.
confirm.jpg / V - Attached On 2019-04-09 09:06:41 UTC - Size: 103.05 KB - 357 views Attachment Deleted. |
[2019-04-09 09:24:20] |
Therefore, the problem is you are using the wrong Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM (Trade Window Settings Not Applying to Chart or Trading DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
