Date/Time: Fri, 31 Jan 2025 03:10:35 +0000
Daylight Savings
View Count: 629
[2019-04-07 23:57:07] |
User204221 - Posts: 5 |
I am currently off by one hour. How do I change my green chart settings to current time? I am at PST. Currently my indicators start at 3pm PST rather than 2pm PST on Sunday.
[2019-04-08 05:01:06] |
Refer to this page to set the time zone: Time Zone Setting You also need to make sure that your computer's clock is set accurately and the time zone is correctly set. For that, refer to: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
