Date/Time: Fri, 27 Sep 2024 03:49:13 +0000
Large volume in Rithimic Data feed vs Sierra Chart
View Count: 794
[2019-04-07 23:00:09] |
User534699 - Posts: 2 |
Hi, I have configured Rithimic Paper trading account , but the data feed on Large volume trade indicator is completely different from sierra charts? I have threshold for Large volume trade indicator to show 99+ contract on sierra charts data feed and it is showing the trades where as the same indicator with similar threshold is not showing any rithimic data feed. Do you know the reason behind this? For you reference I am attaching screenshots. |
scd_chart.PNG / V - Attached On 2019-04-07 22:58:39 UTC - Size: 43.49 KB - 278 views rithimic_chart.PNG / V - Attached On 2019-04-07 22:58:51 UTC - Size: 56.07 KB - 280 views |
[2019-04-08 19:20:41] |
The reason may be because of this setting which is only supported with the Sierra Chart Exchange Data Feed and Historical Data Services: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-08 19:20:46
