Date/Time: Fri, 27 Sep 2024 03:55:01 +0000
Sierra Chart Installer (version 9)
View Count: 1491
[2019-04-07 22:47:13] |
User823591 - Posts: 21 |
I have multiple copies of Sierra Chart installed on my computer .... (version 1880) Because of the multiple copies I've always updated software versions using the downloaded (Sierra Chart Installer/Installer version:7) file. There is now a new installer (Sierra Chart Installer/Installer version:9) to get the most current versions of your software. I noticed there is an added option in the check boxes (Install Optional Components), I couldn't find any documentation explaining the option. What are these optional components, and moving forward should I just leave that box always checked to get the most out of the current software versions? |
Sierra Chart Installer.JPG / V - Attached On 2019-04-07 22:34:58 UTC - Size: 69.61 KB - 614 views Attachment Deleted. |
[2019-04-08 19:37:07] |
The optional components are for Rithmic and Transact and the User Contributed studies. If you need any of those, you do need to enable that option.
