Date/Time: Mon, 21 Apr 2025 04:38:29 +0000
[Programming Help] - ACSIL call to Clear Current Traded Bid/Ask Volume
View Count: 726
[2019-04-07 18:29:00] |
@sstfrederik - Posts: 406 |
Hi, Is it possible to clear Clear Current Traded Bid/Ask Volume using ACSIL? Hopefully this can be added. Thanks, Frederik |
[2019-04-09 09:38:25] |
An ACSIL function for this will be added to the next release.
[2025-03-13 12:29:03] |
User838772 - Posts: 1 |
Hi, is that possible to get the Current Traded Bid/Ask Volume using ACSIL? I'd like to get this piece of information to change the color in the DOM when an imbalance is detected. Thanks Sylvain |
