Date/Time: Fri, 31 Jan 2025 00:04:08 +0000
Endless Recalculation Loop Showing in Log
View Count: 617
[2019-04-06 18:05:31] |
cmet - Posts: 597 |
Have a chartbook with 9 charts open. There are studies from some charts being referenced on others, which I know can trigger recalculations. However, all the charts in the chartbook are getting a full recalculation every second. When the log is opened, it is simply a non-stop scrolling of recalculation notices. Why might this be happening? Occurs even if I am doing nothing and the data feed is disconnected. I've attached the output in a text file. |
Log.txt - Attached On 2019-04-06 18:05:10 UTC - Size: 2.34 MB - 396 views |
[2019-04-06 18:27:50] |
John - SC Support - Posts: 37621 |
You have an indirect circular reference. Chart 9 -> Chart 1 -> Chart 2 -> Chart 11 -> Chart 9. You need to figure out the studies that you have put on that is causing this problem. For help with how to do this refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
