Date/Time: Fri, 31 Jan 2025 00:20:48 +0000
[User Discussion] - Bar's range indicator
View Count: 1077
[2019-04-06 11:08:08]
EuropeanTrader - Posts: 290
Hello everyone,
please help me with the following.
How can I display an indicator or simply value in ticks/cents of the bar's range?
If I put on a "True range" indicator and there is a gap in price (especially if I use specific day session times) this price gap is calculated in the True range indicator. I need to ignore all gaps and if the market gaps 100 points and the first bar is 20 points wide, I need an indicator to display 20 points only . How can I do that please? I can't find a way. Please see attached pic.
Thank you!!
Gregor, Slovenia
imageSH_ 3663 Apr. 06 12.59.jpg / V - Attached On 2019-04-06 11:07:32 UTC - Size: 364.48 KB - 302 views
[2019-04-06 13:58:49]
Sawtooth - Posts: 4164
Use the Average Daily Range study and set the Length to 1.
