Date/Time: Fri, 31 Jan 2025 00:18:37 +0000
Show/Hide order fills destroyed bid ask depth bard displayed
View Count: 968
[2019-04-05 17:31:05] |
User155555 - Posts: 15 |
and shows the last 10 min instead of what was displayed before. Ver 1895. Older version 1865 doesn't have this behavior.
Date Time Of Last Edit: 2019-04-05 17:32:05
[2019-04-05 17:39:59] |
For support you need to log into the support board with your paid Sierra Chart account. Do that with Help >> Support Board and post again.
[2019-04-05 18:31:19] |
Tooth Fairy - Posts: 79 |
Here is my valid paid account. The only reason I posted that as a courtesy for someone using SC depth might wonder if that's a normal behavior. You don't need to fix that because there is a version still working in that regard.BTW, you can change that to user discussion so you don't have to do anything about it. Easy Peasy right?
Date Time Of Last Edit: 2019-04-05 18:41:57
[2019-04-05 19:38:57] |
The first thing to do is to check the Trade Activity Log to see if the order fills you want to see are there: Trade Activity Log: Viewing Historical Trade Activity And then within the chart check this setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Show/Hide order fills destroyed bid ask depth bars displayed in regards to this, provide an image of the chart following these instructions:https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Although nothing has changed with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-05 19:39:46
