Date/Time: Thu, 26 Sep 2024 23:31:31 +0000
DAX Chart Issues
View Count: 810
[2019-04-05 15:48:47] |
Ron009 - Posts: 15 |
http://www.sierrachart.com/image.php?Image=1554478988899.png I can't trade on the DAX Chart. My friend has the Sierra Chart and the same broker and Data plan. His DAX chart works. All my other charts are working and trading fine. Ron Date Time Of Last Edit: 2019-04-05 17:15:28
[2019-04-05 17:52:54] |
Looks like it is a problem with the letter case of the symbols. Do not alter the case. You need to correct this. Refer to: Chart Data and Chart Data Files: Correcting Letter Case Of Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
