Date/Time: Mon, 21 Sep 2026 10:02:02 +0000
URGENT: Sierra Chart wont open chartbook
View Count: 1078
[2019-04-05 15:11:48]
BLAKE R - Posts: 23
My chartbook will not open
I get the tab but no screen opens and all I see is grey.
I have tried to open on two different computers as well.
[2019-04-05 17:22:16]
After opening the Chartbook do you see any charts listed on the CW menu?
If so, then select Window >> Tile Horizontally / Vertically to see if you see the chart windows.
If not, then use a backup Chartbook because the Chartbook contains no charts:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
