Date/Time: Fri, 31 Jan 2025 00:07:13 +0000
market depth window
View Count: 1975
[2019-04-05 15:02:18] |
maclin26 - Posts: 4 |
why when I open the market depth window it comes up with hundreds of prices on the bid/ask side? It usually only shows ten and I don't have to keep scrolling down. Thanks... Maclin |
[2019-04-06 03:09:26] |
When you use the Sierra Chart Exchange Data Feed you can control how many levels you want to subscribe to. Refer to: Sierra Chart Exchange Data Feed You will need to update to the latest prerelease for this functionality: Software Download: Fast Update The setting is controlled through Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Max Depth Levels. The above information is only when using the Sierra Chart Exchange Data Feed which you are not. Otherwise, in the case of Rithmic you need to use this particular setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) But this is only a display limit. It does not change how many levels are actually sent from Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
