Date/Time: Tue, 11 Feb 2025 14:25:50 +0000
[User Discussion] - A few more Numbers Bars enhancement requests
View Count: 908
[2019-04-05 01:20:33]
User873570 - Posts: 27
I have a few additional Numbers Bars requests:
1. For "Highlight Point of Control," allow the row to be highlighted the desired color (i.e. specify the desired background color for that price level) rather than draw a box around it. This should override any other background coloring when set as a background color. Additionally, ideally, alternate text color for this price level should be allowed to be set as well.
2. Allow alternate text colors to be applied for various background colors. When wanting to use light and dark colors on the Numbers Bar background, it's hard for a single text color to work well against all background colors. If it's possible for you to allow the user to define a "light text color" and "dark text color" and then have Sierra apply an algorithm automatically to use light text on dark background and vice versa automatically, that would probably sufficient, maybe even preferable.
3. Provide a column width setting per column. I would like to apply background shading in one column with a single number (or possibly no numbers) printing in the box. I would like it to be much narrower than the other column where I want to see both bid and ask.
4. Allow columns to overlap. This way, I can apply color thresholds and %ages for background color according to one ruleset (i.e. one column), and different color thresholds and %ages based on another ruleset for for text coloring, and have both overlaid on each other. This would free up much space on the chart vs having to use two columns (esp while I can't set the widths to be different).
Thank you as always for the consideration.
[2020-09-12 13:50:04]
owendonk - Posts: 54
+1
[2020-09-12 15:56:24]
Ackin - Posts: 1865
+1
